McCormick Deering 10-20
Brian in Ohio
03-27-2003 10:28:31
I have a 10-20 McCormick Deering, and according to the Serial Number listing on this site, it is a 1936 model. The number on the tag reads KC207348. However, the pulleys on the fan shaft and crankshaft uses a flat belt, which other collectors claim makes this tractor older than 1936. Anyone have suggestions?
ontwill
03-27-2003 14:35:46
 Re: McCormick Deering 10-20 in reply to Brian in Ohio, 03-27-2003 10:28:31
Brian I got a 37 and it takes a flat belt,they were still using the flat belt in 39 for the 22-36 ,the 15-30.Another thing Brian as of Nov.1 1936 all IH tractors were painted red so if you got a high serial# your could be red,if your not sure look underneath back of the oil pan scrap the grease off and the color will still be there. Will.
Brian in Ohio
03-27-2003 15:01:16
 Re: Re: McCormick Deering 10-20 in reply to ontwill, 03-27-2003 14:35:46
I bought this tractor from another collector who has removed most of the old paint, and put a lot of it in primer, so i doubt that I will find many traces of the old paint. However, he said that when he was working on it, he found it to be grey.
Thanks for the info about the fan belt pulleys.
