A Farmall carb
big al
03-28-2003 08:05:46
I'm about to go crazy working on a zenith carb. I've had it off and apart 3 times. It was dirty and I cleaned it. It ran great but leaked out of the weep hole. The spring was off the needle valve so I fixed that. Then it started to splutter so I took off the tank and cleaned all the fuel system real good and took the carb off again and re-cleaned it. This morning it is leaking again. Is there something I'm missing or do I just need to replace the valve and seat? I haven't adjusted the float because it didn't leak before I cleaned it. Any ideas? Thanks Al
Tim K.
03-30-2003 21:13:55
 Re: A Farmall carb in reply to big al, 03-28-2003 08:05:46
The most popular one is a 52499D which takes a C509V but their are 3 others it could be . Some kits cover a couple of different carbs but I want to make sure you get the right one. There should be a brass tag or a casting number on it somewhere. Keep me posted Tim K.
Tim K.
03-28-2003 14:35:55
If you have never replaced the needle and seat that is a good place to start. Put in a good Viton one though they work very well.
big al
03-29-2003 09:00:59
 Re: Re: A Farmall carb in reply to Tim K., 03-28-2003 14:35:55
where is the best place to get one at? Thanks Al
Tim K.
03-29-2003 12:02:28
 Re: Re: Re: A Farmall carb in reply to big al, 03-29-2003 09:00:59
I keep them in stock as I clean alot of carbs for people. I could mail you one or Napa has been doing a good job with older parts lately. I have kits or just the needle and seat. Let me know what you decide. A drippy carb is a real pain.. Tim K.
big al
03-30-2003 07:48:46
 Re: Re: Re: Re: A Farmall carb in reply to Tim K., 03-29-2003 12:02:28
Tim, Where can I find the model number at? I would really like to fix this carb right. E-mail me with what you need to know. Thanks Alan
John
03-29-2003 13:14:10
Tim,
Do you carry a good quality rebuilt kit for a zenith on a farmall 100. I have a leak problem also after having the dealer rebuild. He cobbled the job, so I'll just re-do it myself!
John
Tim K.
03-29-2003 20:35:22
 Re: Re: Re: Re: Re: A Farmall carb in reply to John, 03-29-2003 13:14:10
John, I'll need your carb numbers to match the right kit and the cost is between 20 and 30 dollars and is complete with new shafts {choke and throttle} and all the goodies along with a viton needle. Let me know. Other kits are available but not as complete. See Ya. Tim K.
