10-20 engine also used in?
Bill
03-29-2003 10:20:31
I'm having trouble finding pistons, rings and sleeves for my 1924 10-20. I did find a gasket set and it says it it also good for the F30 and W30. Was this same engine used in several models over the years? Thanks.
F-Dean
03-29-2003 10:49:59
 Re: 10-20 engine also used in? in reply to Bill, 03-29-2003 10:20:31
Bill, The Block, Crank, Rods, Pistons and several other parts are the same. The Head is different - the 10-20 head has the same size intake and exhaust valves while the F-30/W-30 engine has different sized intake and exhaust valves. The cooling system is also different. The F-30/W-30 engine has a water pump like an M and a thermostat. The 10-20 has a gravity based water circulation system like a F-20.
justin
03-29-2003 10:32:02
I will be getting in some NOS pistons and sleeves for the 10-20 in the near future. pistons and sleeves for the f-30 will interchange. As far as the gasket set, make sure the head gasket included is for a 10-20, as the F30 used a water pump while the 10-20 did not (F-30 head gasket is different)
