Super A
Hydraulics Bog Engine.
Brian
03-30-2003 17:40:56
Well I finally got the super A running after a rebuild that's taken me 4 or 5 years. It was a sweet sound hearing it run, that's for sure. I was concerned about the oil pressure, but after about 5 sec the pressure came up to about 50 lbs.
I have one concern however. When the hydraulics lift, everything seems fine, but going the other way, the motor goes under obvious load. It really bogs the motor. Any suggestions ? The tractor sat for about 7 years outside before I even started working on it.
Thanks in advance.
Brian.
Gav-n-Tn
03-30-2003 18:58:35
 Re: Super A - Hydraulics Bog Engine. in reply to Brian, 03-30-2003 17:40:56
Make sure your rock shafts are not binding in any way. If it sat for that long, you probably need to take some things apart and inspect and/or relube.Any binding will put the motor under load because it will put the pump under a load to move binding parts obviously. Hope you find the problem and the solution.
CNKS
03-30-2003 17:56:44
Not unusual. Change the fluid and clean the filter. If you still have trouble, get a gasket and seal kit from Case-IH, take the reservoir apart and clean out all ports/orfices, etc. Also replace the seal inside the pump if you haven't already, as these pumps typically leak oil into the crankcase.
