ALTERNATOR
ALLEN,EAST ,TN
03-31-2003 18:48:28
IS THERE ROOM UNDER THE HOOD ON A 52 M FARMALL FOR A DELCO ALTERNATOR WITHOUT CUTTING THE HOOD? THANKS
allen
04-01-2003 19:52:16
 Re: ALTERNATOR in reply to ALLEN,EAST ,TN, 03-31-2003 18:48:28
thanks to all the info.a friend gave me a good alternator so i am going to use it!!!!
rustyfarmall
04-01-2003 04:56:01
I have a 1940 M with a delco alternator, it fits under the hood very well, although the same type of alternator does not fit very well under the hood of an H.
Steve K
03-31-2003 19:12:36
Probably is enough room. I put one on a super M but I had to modify the adjusting arm and I put a very small washing machine motor belt pulley on it so it would turn faster. I didn't cut the hood. It was a big improvement over the generator.
tractor rebuilder oklahoma
03-31-2003 22:09:36
 Re: Re: ALTERNATOR in reply to Steve K, 03-31-2003 19:12:36
They fit great you just have to make some changes to the adjusting arm
Steve K
03-31-2003 19:21:05
Another thing to consider is the voltage of the M electrical system. If you go to a 12 volt alternator, you will need to change the rest of the system to 12 volt. I believe all of the pre-super M tractors were 6 volt.
Hugh MacKay
03-31-2003 20:12:03
 Re: Re: Re: ALTERNATOR in reply to Steve K, 03-31-2003 19:21:05
I have been told that an alternator from a Toyota is smaller and much easier to fit. It will do the job.
