Will a 2001 or 2000 loader of a 706 fit a 460 without too much modification?
Bryan
04-02-2003 06:31:49
Now that I know that all the parts are there for this loader, how much modification is going to be needed to make it fit properly. I've read some other posts that said that the rear arms go under the axle on an 706/806, where as they butt up againist the 560/460 axles. Any truth to this? How about the front brackets, are they going to bolt right up? Thanks again for the help you can provide.
RPM
04-02-2003 09:10:05
 Re: Will a 2001 or 2000 loader of a 706 fit a 460 without too much modification? in reply to Bryan, 04-02-2003 06:31:49
I used to set-up these loaders new & the sub mounts were complicated and unique to each tractor, they will fit but you will have to modify them a lot.
keith t
04-02-2003 08:49:20
The info you have is exactly right .The trouble with these loaders was that there were many many subframes to fit the many different models of tractors that IH built ,The loader front part was basicly the same for all models .I have seen many subframe cut,welded,and generally blacksmithed to fit.It is easier to cut a long frame down than to lengthen a short one.Use your imagination .They are a real good loader
