Fires up then stalls
Bill Cole/Roche
04-10-2003 22:24:56
Having my relatives over for a clambake this weekend and wanting to show off my IH240U so
I could bring it it back from the brink of waste
pile but failed so HELP Please? Changed push rods and adjusted valves,rebuilt carb,new plugs,ran on
3cylinders with 2 bent rods on #3 cylinder before
changing rods. It just fires up and then stalls.
All your constructive impute will be Greatly app-
reiated. Yes I messed with the timing. Great
forum. BC
Bob M
04-11-2003 05:13:42
 Re: Fires up then stalls in reply to Bill Cole/Rochester NY, 04-10-2003 22:24:56
Bill -
I'm not familiar with the 240 - are the 240 electrics 12 volt?? If so it probably has a ballast resistor in the ignition. And a burned-out ballast resistor will cause exactly the starting problem you are seeing. Try shorting across the resistor terminals with a short jumper wire, or feed the ignition coil directly from the battery and see if the motor now runs.
Another possible cause is restricted fuel flow to the carburetor. If the motor runs a bit longer with the choke pulled it's a fuel flow problem. Pull the fuel line off the carb and check for a solid flow from the fuel line. If you get just a dribble something's clogging the line (plugged sediment bowl, trash in the tank covering the fuel outlet, etc)
Where in Rochester are you located??
Bill Cole
04-12-2003 00:20:14
 Re: Re: Fires up then stalls in reply to Bob M, 04-11-2003 05:13:42
Bob,I live in West Irondequoit and strange place
to see a tractor being so heavily populated but
a guy down the street has a M so I don't feel out
of place. BC
Hugh MacKay
04-11-2003 02:30:47
Bill: My first reaction is flooding in carb. Some of those C-123 engines are kind of touchy on that one. I have one here right now that even with the close to freezing temps we are having over night no choke is required first start of the day. Could be your carb float is keeping gas level too high in carb. Possability float and valve are leaking letting too much gas in. When tractor is not running do you ever smell gas or see a drip from carb.
May be also you are a bit like me, I tend sometimes to hurry a bit too much. Just double check your plug wires in relation to fireing order. I wired one of these in a hurry once, went wrong way around distributor. They will make an attempt to start this way, as two plug wires are right. The two wrong ones however kill the effort.
04-12-2003 00:34:39
 Re: Re: Fires up then stalls in reply to Hugh MacKay, 04-11-2003 02:30:47
Hugh, thanks for your impute and yes gas does come out carb breather also made adjustment on
governor linkage to carb probably messed that
up cause sounds like engine want to go full rpm
at half throttle in starting. Hope to have good
news on Monday. BC
