Farmall h blowby?
Bob
04-12-2003 07:16:36
Last summer I rebuilt my 1942 farmall H, New sleeves, pistons, valves etc. I would say the motor doesn't even have 15 hours on it. When I first start up it has blue smoke for about the first two min then it clears up. Also it has a little blue smoke coming out of the breather tube on the lifter cover. Could this be because my motor is not yet broken in. I have only pulled a light trailer with it so far mostly just riding it around. Any input would be appreciated! Thanks Bob
Phlogiston
04-12-2003 19:23:19
 Re: farmall h blowby? in reply to Bob, 04-12-2003 07:16:36
Are the piston rings set 180 degrees from one another? If they are on top of one another, you can get blow-by.
Phlogiston
Bob
04-12-2003 20:13:13
 Re: Re: farmall h blowby? in reply to Phlogiston, 04-12-2003 19:23:19
Yes I did set the ring end gaps 180 degrees from each other. Thanks Bob
The Red
04-12-2003 12:11:52
Bob did you replace the valve stem guides?
Bob
04-12-2003 14:25:24
 Re: Re: farmall h blowby? in reply to The Red, 04-12-2003 12:11:52
Yes I did replace the guides. Thanks Bob
