What fluid to use in an M rearend?
Bob G
04-15-2003 08:16:42
I am going to change the fluid in the rearend of my M, since it has sat for 15 years. And I really don't remember when it was ever changed. I have heard some people put Hy Tran in, but others say to only put 85W in. What does everyone recommend? Temps don't get below 0 very often and I will probably not be using it then.
Thanks,
Bob
Mike ISW
04-15-2003 20:54:40
 Re: What fluid to use in an M rearend? in reply to Bob G, 04-15-2003 08:16:42
I used 85w140 in my H. Do not use hy-tran in the rear end of your M.
John
04-15-2003 18:36:11
would 85, 90 140 multi wt be ok?
MDJim
04-15-2003 18:24:41
I use 90W in both of my MD's. Both of them 48 models and never had any problems with them.
Randy Hall
04-15-2003 09:32:53
i always use 140 weight gear oil in our m's. it's thinner than the old oil that was in it and it might not leak as easily with the heavier oil and after sixty years of wear there is plenty of clearance for the heavier oil to do it's job. our tractors are working tractors.
The Red
04-15-2003 08:18:51
13 gallons of 85W or 90W.
Will Sick
04-15-2003 19:01:55
 Re: Re: What fluid to use in an M rearend? in reply to The Red, 04-15-2003 08:18:51
80 thru 140 is okay. It should be labeled GL5. This stands for gear lube 5 which will stand the load where the gear teeth meet.
