IH temp gauge
Bryan
04-15-2003 20:36:26
I have a manual IH temp gauge in my Versatile.
I was wondering what the temp ranges are for cold run and hot, This tractor runs on the high end of run (passed the arrow) the oil temp is between 180 and 200 degrees. I would prefer a gauge with numbers but it is hard to find one with 6 plus feet of line. Thanks Bryan
Bermuda Ken
04-16-2003 08:14:49
 Re: IH temp gauge in reply to Bryan, 04-15-2003 20:36:26
The 393841R91 temp gauge from IH has numbers on it and the cord should be long enough too.
Hendrik
04-15-2003 23:49:33
I recently tested the temperature gauge of my Super A while off the tractor. At a water temperature of 200 F the needle pointed at the N of RUN. This gauge is pretty old. You can quite easily calibrate your gauge by unscrewing the sensor end of the gauge and putting it in boiling water. HTH Hendrik
Steven@nd
04-15-2003 20:45:03
I have a 180 degree thermostat in my H and it runs at the bottom of "run" zone at the lowest. I would say top of run would be around 200 or so. Hot would be ~220 I think...
