Hydraulic connections
Bart
04-19-2003 03:38:58
I have a Super M with the factory made hydraulic tank under the gas tank where the battery usually is. It has live power with one control rod on right side. On left side it has two outlets? Are these both outlets? I was thinking of using left top outlet to a two way valve to operate a loader. What would be the proper way to hook this up, for loader up and down and bucket tip. I have four pistons. Thanks for any help. Dick in Vermont.
Brent
04-20-2003 14:22:58
 Re: Hydraulic connections in reply to Bart, 04-19-2003 03:38:58
Not exactly sure if both are outlets, but you could hook up to then to find out, or look in a service manual. You could run one outlet from the tractor to the spool valve inlet (get a 2-valve if you want to run loader arms & loader bucket) and the outlet from the spool valve would run back into the hydro tank. On my H it goes back in through the hydro drain under the tractor, not sure how your tank is plumbed since it is a live system and tank is different.
Bart
04-21-2003 16:27:44
 Re: Re: Hydraulic connections in reply to Brent, 04-20-2003 14:22:58
Thanks Brent. That sounds like it would work for a loader.I just have to figure out how to get the return hose hooked up. Thanks again.
Gary-Miss
04-19-2003 14:42:52
Your LIFTALL on your tractor,according to theIH service manual GSS-5034, has a max pressure of 800 psi )This is the late model,early models kicked off at 450 to 500 lbs). There's a good bit o reading on the four positions of the valve. It will work for a front end loader and you can even set it to feed a remote open center spool valve or a manifold of valves so you can operate multiples of single action or double action cylinders according to the book and, this isprobably what I would suggest (feeding off the right outlet to a open center spool valve. Make certain the liftall can breathe or there is a possibility of breaking the case.
Bart
04-19-2003 15:01:14
 Re: Re: Hydraulic connections in reply to Gary-Miss, 04-19-2003 14:42:52
It's not a lift-all system. It's live power, pump in front of distributor. Tank under gas tank, not under tractor belly. Thanks anyway.
