What do I have?
Allen
04-23-2003 13:54:24
I bought a tractor at an auction (cuz the wife likes yard art) its a complete tractor but not yet sure of engine condition, been sitting many yrs. was sold as a 1929 f-20 but someone at the auction said its a regular, bieng a mm tractor person im not familiar with any farmall stuff, so, how do I find out? havent yet found any tags or numbers on it. it is probally restorable but not sure i'll dive into this one.
Bill B
04-23-2003 16:27:58
 Re: what do I have? in reply to Allen, 04-23-2003 13:54:24
third party image
The regular has a gear drive steering, usually open gears, but the last ones had a cover. The later F20 had worm gear steering enclosed in a cast iron case. You can spot the worm gear steering because the shaft goes into the gear case offset from the centerline of the bolster. The regular came with a manifold that exhausted out the bottom, with an elbow arrangement of cast iron. It also had a small brass carburator. The F20 exhaust comes out the top, through the hood, and the carb is larger and cast iron. There are several other differences, but those should start you on the trail. The ID tag was originally on the tool box, under the gas tank. If it is gone, the ID number is also on the frame rail in pretty large characters. F20 will start with F20. Here is a pic of an F20.
allen
04-24-2003 13:54:30
 Re: Re: what do I have? in reply to Bill B, 04-23-2003 16:27:58
thanks Bill, this info should point me in some direction. however, concearning the manifold, it came with two. I was told one is a cold and one is a hot manifold. the carb is small and brass. I'm suspecting its a regular. is that the same as an f-12 or f-13?. thanks again steering gears were enclose in a cast bolster (broken open) and looks like ring and pinion style gearing., thnx agin, Allen in kansas
SAm in NS
04-23-2003 14:58:59
Don't know too much about the earlier Farmalls but I think one easy difference was the Regular had an open steering gear and this was enclosed on later models. I think the serial No. (if it's still on there) is on a plate on one of the gas tank supports (or in that general area). Hope this helps. SAm in NS
Allen in ks
04-24-2003 19:17:00
 Re: Re: what do I have? in reply to SAm in NS, 04-23-2003 14:58:59
thanks, guess I'll climb around it more. it has a closed but broken gear box.
