No timing advance
Bill Cole
04-24-2003 14:53:42
After changing push rods,spark plugs,removing distributor and reinstalling I have no timing advance. Set timing at idle with light and increase to full rpm and doesn't advance and vice versa. All help appreciated. BC
PS: also checking archives.
Bob M
04-25-2003 05:18:53
 Re: No timing advance in reply to Bill Cole, 04-24-2003 14:53:42
Bill - If the tractor sat outside, there's a good chance water got into the distributor. Rusting then may have stuck the centrifugal advance mechanism. You might pull the distributor and disassemble/clean/lube the advance mechanism.
I'm uncertain of the actual number for a 240, but believe the spark should advance 30 or 35 deg between idle and full RPM.
Bill Cole
04-25-2003 06:22:01
 Re: Re: No timing advance in reply to Bob M, 04-25-2003 05:18:53
Thx Bob: I think the 240 is loving the attention I'm giving it because of NOT being cared for in the past years. It ran decent at the dealers and now one thing after another. Oh well it will keep me out of trouble. BC
Bob M
04-25-2003 07:50:03
 Re: Re: Re: No timing advance in reply to Bill Cole, 04-25-2003 06:22:01
Bill – I live near Rochester myself (motto should be “where the sun rarely shines”). My experience is even well cared for tractors here often struggle on account of the persistant wet weather.
If you visit an old tractor show in the area notice how many tractors on display have their distributors/magnetos bagged in clear plastic. There’s a reason for this!! ...Bob M
Bill Cole/Rochester NY
04-24-2003 14:56:53
Sorry it's a IH240U 1960 I'm sure this might help
BC
here, try this
04-24-2003 16:24:39
 Re: Re: No timing advance in reply to Bill Cole/Rochester NY, 04-24-2003 14:56:53
i got an M running for a friend who said it "wouldn't stay timed" All that was wrong was someone had used too long a screw to fasten the condenser. It was jambing the advance. I would take it off and give it a good inspection and cleaning. there are two wieghts and tiny springs that get rusted and lost.
Ernie
04-25-2003 11:25:36
 Re: Re: Re: No timing advance in reply to here, try this, 04-24-2003 16:24:39
Rebuilt a distributor for my M once upon a time. Replaced the shaft (which includes the breaker mounting plate) with a new part from the dealer. I had the same problem with no mechanical advance. Turns out that the part they gave me, though it fit, did not have a long enough slot in the plate for it to advance properly. Finally figured this out and modified plate and now it works like new.
