Order Farmall Cub Parts Online
Cub tractor wont Start
Bill Torok
04-26-2003 16:34:27
Help im at wits end. A friend has a farmall cub that won't start. I have checked everything New coil in mag. checked timing OK. Seem to have a weak spark at plugs.Coil fires spark 3/4 inch away from ground. IS it possable to have a weak spark and have aspark like that? could it be a bad condensor? He has had this a while always
started after rolling over 2 times on a 6 volt system.then one day it would not start.cleaned carb fired right off 6 or7 times has not ran since. founds bad coil fixed it.don't know what to do. any ideas anyone
thanks. vonbeefer
Bill L Md
04-27-2003 06:43:15
 Re: Cub tractor wont Start in reply to Bill Torok, 04-26-2003 16:34:27
Bill, put solid core wires on her that will make the yellow spark go back to a blue spark. Had the same problem with my 49.I was about to pull my hair out trying to figure that one out,Big Dog straightened me out on the wires, carbon wires don't allow enough energy to get to the plugs.
LITTLE RED
04-26-2003 20:16:32
IF YOU HAVE DONE ALL THE IGNITION STUFF I WOULD GO BACK TO THE FUEL SYSTEM A LITTLE DIRT OR RUST IN THE INLET SCREEN ON THE CARB WILL SHUT YOU DOWN
QUICK JUST WENT THROUGH THE SAME WITH MINE AFTER SITTING ALL WINTER CLEAND THE TANK BLEW OUT THE FUEL LINE AND SHES PURRING LIKE A KITTEN GOOD LUCK
Bigdog
04-26-2003 18:18:07
Tune-up time! New points, condensor, rotor, rotor cap and wires if necessary.
Clipper
04-26-2003 17:12:47
Had the same problem with my Cub when I first got it.What I did was: 1)new plugs 2)new wires 3)new coil 4)new Points 5)cleaned w/emory cloth every single electrical connection 6)new voltage regulator...that was 3 years ago and she fires up every time....hope that helps you.
