Farmall MD Fuel System
Adam
04-26-2003 19:20:47
I just bought a Farmall MD and the diesel that is in it doesn't look or smell very good. I want to drain the system out as good as I can before I try starting it. What plugs do I pull and how do I get fuel back in the lines before starting it. Thank You, Adam
Red Rider
04-26-2003 20:16:20
 Re: Farmall MD Fuel System in reply to Adam, 04-26-2003 19:20:47
You can drain the tank, both filters and the lines from the pump to the injectors pretty easy but trying to get the fuel out of the pump and injectors is not very easy. Besides old diesel really won't hurt any thing anyway. I would just clean the tank, the fuel filter cans & bases, install new filters and clean the water trap. If it runs well on the gas cycle start it up, cover the radiator to warm it up quickly and I'll bet ya it will run on diesel. It might not run its best until it burns the old diesel out of it but It won't harm anything.
