Electronic ignition
58 K
05-06-2003 18:18:32
I would like to know if i can get a 6 volt electronic ignition for my 46 m . If so where do i need to look? Think someone had one on here awhile back. But don't seem to find it in archives. Thanks for your help. 58 k
Doug in OR
05-07-2003 09:06:22
 Re: electronic ignition in reply to 58 K, 05-06-2003 18:18:32
Pertronics also has them. They cost a bit more than the 12 volt, negative ground systems. Before you purchase the 6 volt unit, ask yourself if you wouldn't rather convert the tractor to 12 volt, negative ground. It really isn't that costly to do this. After doing this, you can buy stock 12 volt ignition systems, which are more readily available.
Steve - IN
05-06-2003 21:16:29
58K,
I think Genesee Products now has an electronic igniton for 6V pos ground Farmalls.
Check out the link below.
dave
05-06-2003 18:41:52
I think that you have to have a 12v neg ground system for the electronic ingnition.
