How do I remove an oil pump from an A?
Brad
05-09-2003 17:05:23
The I&T manual says that removing an oil pump from a Farmall A is apparent after removing the oil pan. Well, it isn't apparent! I have removed the two bolts from the outside of the engine that hold the lower portion of the pump, but, how do I force the pump down out of the flange in the block that holds the upper part?
Brian
05-10-2003 06:36:29
 Re: How do I remove an oil pump from an A? in reply to Brad, 05-09-2003 17:05:23
When I removed mine, I recall having a hech of a time. After I removed the pick up tube, I used a very small hammer to "tap" the pump out. I also tried twisting when I could if I recall.
Hope this helps.
J MIRGON
05-09-2003 17:50:48
BRAD,
JUST DID MINE RECENTLY, AFTER YOU REMOVE THE TWO BOLTS ON THE OUTSIDE OF THE BLOCK IT SHOULD SLIDE OUT OF THE UPPER HOUSING, YOURS MAY JUST BE GUMMED UP A BIT. YOU MAY TRY USING A SMALL SCREWDRIVER ON THE INSIDE OF THE BLOCK IN THE OIL PUMP MOUNTING HOLE AND PRY DOWNWARD ON IT.
GOOD LUCK
bsandersga
05-13-2003 05:21:31
 Re: Re: How do I remove an oil pump from an A? in reply to J MIRGON, 05-09-2003 17:50:48
Thanks, guys. I finally got it off. I had to use a pry bar and a little persuasion, but once it broke loose it came out easily.
