Re-build/Maintenance on Hydraulic Pump??
BobG in VA
05-11-2003 20:35:29
Tractor: '57 Farmall 230. Issue: I think I need to re-do the hyd. pump. I seem to "gain" crankcase oil (not much, but I'm certain theres more there now than when I changed the oil this spring). I assume it's from the pump?? Is this hard to do and does the O-rings, gaskets, etc, come in a kit or are they purchased separately?? Anyone Know?? thanks-- BobG in Va
Peabody
05-12-2003 05:23:58
 Re: Re-build/Maintenance on Hydraulic Pump?? in reply to BobG in VA, 05-11-2003 20:35:29
Not hard at all, Bob. About a 45 minute job, start to finish. The parts used to come in a kit, but I don't believe anymore. Your IH parts man should have them in stock, consists of a few o-rings and a seal. Good luck!
BobG in VA
05-12-2003 10:04:46
 Re: Re: Re-build/Maintenance on Hydraulic Pump?? in reply to Peabody, 05-12-2003 05:23:58
Peabody: Thanks for the quick reply. I'll check it out. BobG in VA
