Order Farmall Cub Parts Online
Cub A-136 Cultivator Conversion to Hydraulic Lift???
B. Mahar
05-14-2003 06:19:02
I just picked up a a nice set of A-136 cultivatots for my 53 Cub. It is a hand lift set. I have hydraulics on my Cub, and am writing to ask if there is a relatively simple way to switch over to hyrdaulic lift.
Thanks in advance for any help.
B. Mahar Savoy, MA
gene b
05-14-2003 19:47:04
 Re: Cub A-136 Cultivator Conversion to Hydraulic Lift??? in reply to B. Mahar, 05-14-2003 06:19:02
The A-136 cult is for an A. You will have a great time trying to put it on the CUB. Better get the rite one for the CUB. The square bkt that goes to the steering sector will have to be redone.
Farmalldan
05-14-2003 10:02:39
The A-136 cultivator was built for the A and not the Cub. There are a number of differences between the two which will cause you to make modifications. In my opinion, you would really have better luck with a Super A cultivator as it at least lifts with the same mechanism. Anyway, I believe you will find the square bar that goes into the steering gear hsg to be a different size, the brackets that mount the rear sections to the final drives to have different bolt patterns, and the way the sections lift is entirely different. My comments are made on the basis of observations of an A-134 cultivator that I acquired with a Cub. I never tried to attach the A-134 as I had Cub cultivator also, but these were the obvious modifications made by the previous owner. I think you're into new ground here, so good luck.
George Willer
05-14-2003 06:34:08
I don't know the number, but I imagine all cultivators would work the same. Just install them as is and they will work fine. The attachment points are the same on Armstrong and Hydraulic lifts.
George Willer
