656 hydraulic pump
Bob
05-19-2003 15:00:05
I have a 656 that the hydraulic pump is not getting enough oil . It has a new pump and filter and oil I have cleaned the rearend out and a couple other places out does anyone have know where it could be getting robed of oil.
Aces
05-19-2003 15:53:36
 Re: 656 hydraulic pump in reply to Bob, 05-19-2003 15:00:05
656 has a recycle tube in the back if it is bad it can leek air and cause bad hydraulics the cross over tube from filter to the pump and a o ring between the TA housing and the rear end could be bad.
Stan
10-12-2004 18:49:22
 Re: Re: 656 hydraulic pump in reply to Aces, 05-19-2003 15:53:36
Anybody know where the recycle tube is on the tractor? It sounds like my 656 hydro is suffering from the same problem but it takes out the hydro drive, steering, aux hayd, 3 point but not the PTO. Any ideas out there?
Stan
bob
05-19-2003 20:24:15
When you take the filter out it is not starving as bad.
