Timing gears on a H
Bob B.
05-24-2003 19:49:37
Need a little help. I am in the reassembley stage on rebuilding my 1948 "H" engine. How do you set the timing mark when the magneto gear/housing is installed? I aligned the two dots, crank and cam dots, when I installed the camshaft, but am a little confused on how to get the mag. aligned. There are two dots on the cam gear directly across from the dot to align the crank and cam.
Thanks in advance. There is a dot on the mag. gear also.
MIke ISW
05-25-2003 06:15:41
 Re: Timing gears on a H in reply to Bob B., 05-24-2003 19:49:37
When I rebuilt my '48 "H" I aligned the single punch marks on the cam and crank gears. Mine is a distributer ignition but there was a double set of punch marks on the cam gear and also a double set on dist drive gear which I aligned and all is good. Good Luck, Mike
