Rebuilt Super A.
Brian
05-24-2003 19:59:05
I was thinking about carbs today, and started wondering. Since I went from the original 3" bore to a 3.125" bore, do I need to adjust anything in the carb ? The Tractor seems to run fine, although I have to give it quite a bit of throttle and some choke in order to get it to start, even after the engine is hot.
Thanks
Brian.
Gary-Miss
05-25-2003 11:23:55
 Re: Rebuilt Super A. in reply to Brian, 05-24-2003 19:59:05
You aren't supposed to have tochange the settings due to the increased bore, however, rules are made to be broken. If the tractor idles good, you should beable to crank it at idle with no choke when warm.
