My M won't move
Bob
05-26-2003 13:49:02
My old M has been setting for quite some time. Won't start. Worked on it a couple of weeks ago and it turned over fast, 12v convertion..I would squirt WD 40 or gas in the carb and often it would fire a couple of times as it it were going to start. But, all the time it was turning over, gas was pouring out of the bottom of the carb in a steady steam. So, figured the float must be stuck. Bought a new carb kit and got the float working freely. But, the kit didn't include a needle valve of valve seat. So, now it turns over fast, but can't seem to get it fire at all.What can I do?
here, try this
05-26-2003 17:14:58
 Re: My M won't move in reply to Bob, 05-26-2003 13:49:02
the first thing i would check is if you even have gas in the carb. just take the plug out of the bottom and make sure you have a good full flow. next you will likely have to take the carby back apart. make sure all the holes are open. I like to use carb cleaner in an arosol can. squirt into each hole you find and watch to see where it comes out. THERE ARE NO DEAD END HOLES
pete
05-26-2003 13:59:31
sounds like needle is not passing gas,try on starting fluid,if runs ,carb problem
