Lubrication farmall m
Bubba
05-26-2003 19:16:16
I have a 1943 farmall m. Can you tell me what lubricants (weight,capacity) and which part it is used for, i.e. tranny,engine etc.? I have no manual. Any help appreciated.
here, try this
05-27-2003 04:27:47
 Re: lubrication farmall m in reply to Bubba, 05-26-2003 19:16:16
just keep any good oil in the motor that you would use in your car. 8 quarts. opinions very but for light use the multi weight oils are fine. The transmision holds 13 gallons of 85-90 weight. The belly hydralic pump can use any light oil. If you are going to use it I would put in Hy-tran fluid from I-H. Also check the belt pulley, it holds a quart or two of 85-90 weight. Even if you aren't useing the pulley it is a good idea to put it in gear once a year or so to oil the bearings. The water pump gets a grease gun. I'm sure I'm forgetting something. You realy nead to get a manual.
