300 IH, COIL CONDENSER BLUES
BOB - BAMA
05-29-2003 10:18:27
CAN ANYONE TELL ME WHY I KEEP GOING THROUGH COILS,POINTS AND CONDENSERS? I HAVE A 12 V0LT SYSTEM AND ITS WORKING @ 13VOLTS ( O.K. ). I PUT A BALLAST RESISTER AND 12V CONDENSER & COIL ON FOR THE 3rd TIME IN 100 HRS OF OPERATION. THIS IS A PAIN IN THE BUTT!!!!! THE STUFF I GET IS COMING FROM AUTO-ZONE. ANY HELP WOULD BE GREAT!!!
THANKS
dan
05-29-2003 19:47:36
 Re: 300 IH, COIL CONDENSER BLUES in reply to BOB - BAMA, 05-29-2003 10:18:27
Do you have a multimeter to check to make sure that you are actualy only getting 6 volts or so to the distributer? All ballast resistors are not created equal. some early gm ones run 9-10 volts. Chrysler runs 6-7 volts usualy ford is about the same as chrysler. It is realy amazing how stupid parts men can be if you go in there and ask for a 6 volt ballast resistor sometimes. Most have no clue whatsoever about points systems anymore. I just worked on an old vw bug for a neighbor that had been to 3 different shops recently and none got it right. All it was was a simple tune up. They set the point gap at .004,should have been .014, Timing was about 30 degrees and should have been 0 static, The valves wich are solid type just like on our farmalls were set like hydraulic lifters. Down till they touch then 3 more turns.They should have had .04 clearance dead cold. Any other car but a bug would have never run again after that kind of abuse. I got it all fixed right for the lady and she said she never heard it run so good. The last shop also tried to sell her a new trans because it grinds (with an unexperienced driver) going into 2nd gear. Have ya'll ever seen a nonsyncronized trans that wouldn't if you didn't know how to drive one? anyway sorry about the rant but I was just trying to explain how parts places and garages can be pretty clueless when it comes to old iron nowdays. On yours if your ballast is too hot That could burn points but I doubt it would the coil if you have a 12 volt coil. Bad grounds or the points staying closed with current flowing when it isn't running could cause a fried coil. Are you sure the coil went bad? A loose shaft would definitly burn points in a hurry by making a short arc on one side of the dist rotation and a long one on the other side. Long arcs fry points and short ones will usualy not run or will fuse them together.
I would get a bushing made for the distributer and buy a new shaft if it is worn at all. Make sure the machinist drills an 1/8 inch hole all the way in one side and out the other where the grease fitting or plug is. It's amazing how many new ones I have seen without that very important hole. You can replace the shaft yourself if you have a drill press ( I really don't recommend doing it with a hand drill). You have to drill a 1/8 in hole for the pin that holds the gear on. Might as well replace the gear too while in there. On the top of the distributer , I forget the part name, But the cam on top that controlls the advance needs to not have any wiggle too. I had to bush mine since it is no longer carried by IH. Make sure the advance springs are good but best to replace since you are doing all this work. Finaly set the points according to spec and use IH parts for tuneups. I disagree with a previous post about the IH dealer being cheaper than autozone but autozone quality is seriously lacking. IH factory parts may look different from the originals now but is of the same fine quality for the most part. I only buy oil at autozone anymore because I have been burned too many times by their junk parts. One more thing make real sure you get the correct shaft from the IH dealer. There are many different ones for the same distributers like for example my super c uses different advance springs and shaft because it has firecrator pistons. There are also different ones for step heads, flat heads, whatever, you get the picture. write down all the numbers on your engine and head and try to determine the type of pistons in it. Firecrators run really bad with the wrong distributer build and vice versa. Hope I helped some. sorry it got so long winded.
jmyt_47
05-29-2003 11:06:55
If you have a ballast resistor, you should have a 6V coil, condenser. From my experience, the points don't last too long at 12v. Your IH dealer should be cheaper for ignition parts.
jal-SD
05-29-2003 11:17:05
 Re: Re: 300 IH, COIL CONDENSER BLUES in reply to jmyt_47, 05-29-2003 11:06:55
My 6V H distributor kept going through points, etc. until I had the bushings & shaft rebuilt @ my C-IH dealer, after it fried the 2nd coil. (I'm a slow learner.) It was spendy, but less expensive than a new distributor & no more aggervation. Could your problem be that the bushings are wore out? (My $0.02 worth. jal-SD)
bob-bama
05-29-2003 12:48:22
 Re: Re: Re: 300 IH, COIL CONDENSER BLUES in reply to jal-SD, 05-29-2003 11:17:05
jal SD- how much did it cost to replace / rebuild the shaft and how would a guy test for such a thing??? at a high rpm would the shaft wobble and ware down the points, causing the coil to get hot and break down insulation on the coil because the condenser can't fire ??? i don't know just guessing.....hey thanks and if you can let me know $$$ what the cost was would be great!!
aloha
jal-SD
05-29-2003 14:55:02
 Re: Re: Re: Re: 300 IH, COIL CONDENSER BLUES in reply to bob-bama, 05-29-2003 12:48:22
If I remember right, the cost was about $150 to $175, w/parts about half that cost. I took the tractor to their shop, they took it off & put it back on, so lots of labor. (I don't do well on timing, so I have to pay for my lack of knowledge.) As I remember, there was both vertical & horizontal movement apparent on the shaft, after you got to the points. My shaft was shot, too. Other than points, the H's distributor had more than 50 years (its been in the family that long & I know it had never been worked on before) of use w/o a problem, so I didn't think it was all that much $$ considering its use. We used to farm 800A with it & 3 other H's, so it had seen LOTS of running hours. (Another $0.02 worth. jal-SD)
bob-bama
05-29-2003 17:58:04
 Re: Re: Re: Re: Re: 300 IH, COIL CONDENSER BLUES in reply to jal-SD, 05-29-2003 14:55:02
jal SD
that sounds good to me , i just broke a track on my dozer about hour ago. so whats a $175.00!! thanks, now comes the hard part or parts!!
i will let you know how it goes!!
ALOHA
