Farmall H blows oil out of air cleaner
Ben Wolfgang
05-31-2003 14:26:41
hello i have a h farmall and it hasnt ran for about 2 years i hooked up the battery, and then i put some gas in it and changed the oil bath i filled it up to the line, and when the tractor cranks over, it shoots oil out the air cleaner stack. it never did this before. its got spark, and exhaust come out when i crank it. CAN ANYONE HELP????? ? Thank YOu
kjm
05-31-2003 19:17:01
 Re: Farmall H blows oil out of air cleaner in reply to Ben Wolfgang, 05-31-2003 14:26:41
Ben, I agree with Jerry, stuck valves. Remove the valve cover and soak the valves good with PB Blaster and tap on the valves with a rubber hammer,most of the time they will pop back up(you can hear when they come up) after they are free tap on all of them to help reseal the valves and seats.lol kjm
VAJerry disregard above
05-31-2003 14:47:35
I misread where you said the oil is coming from. The air cleaner sounds like a stuck valve, The oil is comming from the air cleaner. The air from around the valve. Pull the valve cover a possibly as you turn it over you will see the valve with lesser movement. Or better yet do a compression test. Sorry for the miss understanding.
VAJerry
05-31-2003 14:36:32
Blow-by issue. Rings bad or siezed in grooves.
VAJerry
05-31-2003 14:42:42
 Re: Re: Farmall H blows oil out of air cleaner in reply to VAJerry, 05-31-2003 14:36:32
Let me be more specific. What happens is when the plug fires some of the gasses are forced by the rings into the crankcase, the outlet for these gasses is the breather.
