Replacing Water Pump on '49 H, what parts needed?
Brent
06-02-2003 05:30:07
My water pump started leaking this weekend and I am going to tear it off and replace. I already purchased a pump and pulley in anticipation of this moment. What else do I need, and where can I get it? Gasket (do you use RTV sealant too, or just the gasket?), connecting hoses, and what else may I need? I have a shop manual but any words of wisdom from those of you who have done this before would be appreciated. Thanks!
RC
06-02-2003 06:25:37
 Re: Replacing Water Pump on '49 H, what parts need in reply to Brent, 06-02-2003 05:30:07
Sounds like you have everything you will need to replace your water pump. I used RTV sealant and gaskets when I rebuilt the water pump on my '46 H. I also used a little RTV sealant on the hose outlets before tightening the hose clamps on the hose ends. Be sure you take the packing nut off the front end of the water pump and check to see there is packing behind it. If there is not enough you will need to get some. The packing can be obtained from any IH/Case dealer and is part# 45925DA.
