Woodruff keys in wide front on M, slot is worn.
Bob G
06-04-2003 05:53:25
I have been working on my 49 M, getting it ready to cut hay with. It has a wide front end and the wheel assembly that has the spindle on it has Woodruff (half moon) keys that attach the steering arm. The slots for the keys are worn some and a 1/4 inch key is sloppy in it. This allows the steering arm to move on it. What is a solution to fixing this, recutting the slot wider for a thicker key or ?
Thanks,
Bob G
Jim
06-05-2003 07:33:26
 Re: Woodruff keys in wide front on M, slot is wor in reply to Bob G, 06-04-2003 05:53:25
We use JB weld to hold a new key in the slot.
dlp
06-06-2003 19:13:52
 Re: Re: Woodruff keys in wide front on M, slot is in reply to Jim, 06-05-2003 07:33:26
If I might make a suggestion which you might be doing anyway: Lay the shaft flat & heat the slot up just a little. When you apply the JB weld to it will flow down into it & make a better fit to the key.
here, try this
06-04-2003 18:16:05
take the next bigger key and grind on it till it fits. that's what i do.
Val
06-04-2003 10:27:11
I have milled a straight keyway in the spindle shaft right thru the woodruff keyway. This allows the use of the ends of the slot in the steering arm. I use a square key the full length of the steering arm. Make sure you can tighten up the steering arm so that it is tight to the spindle. May need to widen the slot that get pinched together and I recommend a good quality fine threaded bolt.
Dave_Id
06-04-2003 07:09:45
One solution would be to machine a new slot 180 degrees from the old one. Another solution would be to weld the existing slot and remachine.
