H steering
Bobby
06-07-2003 18:08:16
Dumb question. Seeing as the steerin gear(sector or ring) only has teeth on 1/2 of it what keeps the front wheels from going all the way around when you keep turning the wheel?
Bob M
06-07-2003 18:24:34
 Re: H steering in reply to Bobby, 06-07-2003 18:08:16
Bobby - Look up under the tractor front end casting. There's 4 bolts that attach the lower bolster to the upper bolster pivot shaft. The bolt in the right front corner has a special extended head that fits up inside a crescent-shaped slot cast in the underside of the front end casting - it sets the left and right turn stops for the steering.
Punch below for a photo of the assembly from when I had mine apart...
Bob in SE Nebraska
06-07-2003 18:17:20
Where the lower bolster bolts to the upper bolster there is a bolt with a special head that limits travel. It is one of the four bolts and is the one at the right front.
Bob
