Alternator problems
BEL@IN
06-08-2003 11:33:12
The alternator on my tractor is not working. The dash warning lite is off all the time,switch on or off. I took it off and had it tested and tested OK. Put it back on and worked one time. Then the same problem. This all started when the battery was dead, it`s possible the switch was left on. Any ideas would, as usual be greatly appreciated.
Ben in KY
06-08-2003 19:52:48
 Re: Alternator problems in reply to BEL@IN, 06-08-2003 11:33:12
Does your alternator have an internal or external regulator. I was helping a friend work on his 444 today and he had the same problem, turned out to be the external regulator.
steve
06-08-2003 19:22:15
Im not sure i understand exactly what you are doing, but if you have a dead battery and jump an alternaotr powered vehicle, it may run poor, and may not charge the battery. you must have a signal voltage to the alternator to make it "kick in" and start to charge. another possibility is that the wiring to the alternator is corroded, or not connected properly.
