154 crankshaft pulley
Ag-man
06-15-2003 15:47:10
The crankshaft pulley is spinning like a top. When I put a wrench on the cap screw the engine turns. Two questions:
1. What is the best way to lock the drive train in order to remove the cap screw? I left the tractor in gear and it just rolls forward when I put pressure on the screw.
2. What am I most likely to find under the pulley? Key Way? How does it lock in place?
John
06-15-2003 18:33:56
 Re: 154 crankshaft pulley in reply to Ag-man, 06-15-2003 15:47:10
I have used an impact wrench for this before but you may have to pull the radiator off. It usually gets the bolt off before the engine can spin much, especially when in gear and the brakes locked. The down side is the posibility of breaking the bolt but usually when I get to this point I am out of options. On a GM 350 diesel, I had to replace the valve that shuts off antifreeze to the heater, I couldn't use a wrench, crowfoot was opening up so I decided to cut off the valve so I could get a socket on what was left, tried by hand , no luck so took the impact wrench and had it off a few seconds later. I have gotten things off with the impact wrench that I tried by hand with cheeter bars with no luck.
49 Cubber!
06-15-2003 16:51:18
Lock the brakes with it in gear!I think theres a keyway in there,I dont recal right now but almost sure it is there
