Plugs on hydra touch valve-HELP PLEASE!!!!!!!!!!!!
big red 1
06-16-2003 05:06:54
Im cleaning off some of the prior owner add on options ha ha from my 560 gas and in the bottom of the far right valve bank he had two hoses for something screwed in the back one came out ok however the front one snapped off about flush with the casting,Some one please tell me that these could have the original screw in plugs and that there are no reverse threads,the tractor is nothing special just a 560 rowcrop,looks I will need to go to the machine shop or buy a big easy out any advice is appreciated and thanks in advance
KX
06-16-2003 12:03:59
 Re: plugs on hydra touch valve-HELP PLEASE!!!!!!!! in reply to big red 1, 06-16-2003 05:06:54
No reverse threads but that could be hard to get out. Just be patient and don't damage the threads on the valve body. Try to turn it out with a cold chisel inside the broken off piece first, hit it in several places rather lightly then increase power of the blows but keep rotating the chisel around till it starts turning. Watch and make sure you aren't cutting through the nipple into the valve body threads. That is what I would try first anyway.....best of luck.
