560G misses when not under load
Brent in IA
06-16-2003 10:29:23
My 1962 560G misses (sputters) when running at full throttle unless you hit a hill or something that puts it under load, then it purrs (growls) like a cat and doesn't miss a beat. Anyone have any ideas what may be up? Gas is good and filter/screen is clean.
C Kulig
06-17-2003 05:15:38
 Re: 560G misses when not under load in reply to Brent in IA, 06-16-2003 10:29:23
Brent, sounds just like what my 806 does when the plugs are getting bad. I'd change plugs and probably points while i'm at it. Might not be your problem but it was mine. Good luck!
Chad
here, try this
06-16-2003 18:15:15
ignition
Brent in IA
06-17-2003 05:06:39
 Re: Re: 560G misses when not under load in reply to here, try this, 06-16-2003 18:15:15
Thanks, but what would cause it to miss under no load but not miss under load? Wouldn't the ignition be firing the same regardless? I had assumed (probably wrong) that it would be fuel related because when the governor kicks in it runs great. Could you point me to a possible ignition problem (plugs, points, etc...).
