IH Farmall Super C needs carburetor float
Bruce Haverkamp
06-18-2003 08:18:41
I am in need of a float for a CARTER UT carburetor. Does anyone know where to find one. I checked at the IH dealer and you can only buy the carb. kit and the float is unavailable.
Big Orn
06-18-2003 14:26:46
 Re: IH Farmall Super C needs carburetor float in reply to Bruce Haverkamp, 06-18-2003 08:18:41
Ditto on the JB weld. Used QuickSteel myself - same thing, just easier to apply. Couldn't find a float without buying the whole kit. I removed the float, cleaned it, sanded it, cleaned it again with carb cleaner, let it dry and smeared just a little bit of the epoxy on it (so it wouldn't weight it down too much) and reinstalled it. Works fine. Also - if you solder it - make sure it is COMPLETELY free of all gasoline or BOOM!
Peabody
06-18-2003 11:22:01
What's the nature of the problem with your existing float? I had a leak similar to FC's and fixed it with a dab of JB weld. There was a Carter carb for a Super C listed on Ebay within the past couple of weeks. They show up there from time to time.
Bruce H.
06-19-2003 10:25:50
 Re: Re: IH Farmall Super C needs carburetor float in reply to Peabody, 06-18-2003 11:22:01
The float does not have a leak. Shaking them and holding them to your ear and I can not hear or feel like they have taken any gas inside. It just seems to have lost it buoyancy. I know this sounds impossible. After I let it run for about 2 minutes it starts to leak gas out of the carb. bowl and then sputters.
Big Orn
06-19-2003 11:17:10
 Re: Re: Re: IH Farmall Super C needs carburetor fl in reply to Bruce H., 06-19-2003 10:25:50
"It just seems to have lost it buoyancy." Could be its got "dregs" in it, that very fine junk that seeps into everything once rusts starts. What about hooking a water line or a jug with alcohol in it(free flowing-gravity fed) onto the carb and depressing the float and see if the needle and seat is bleeding by?
Chad Penny
06-18-2003 09:29:16
try calling phils tractor and ask for Tracy he will help you if he can I have got lots of carb parts from him. (810)-395-7847
he is located in Capac Michigan.
Chad
FC
06-18-2003 08:58:39
I ran into the same problem a year or so ago with my C which had the carter UT. I had gas in mine and it was leaking at a solder seam. I got lucky and found the leak, cleaned it up and re-soldered it and it works fine now. Maybe someone will be able to provide a source for these.
