Order Farmall Cub Parts Online
Farmall Cub Fuel Tank
Bruce
09-20-1999 20:38:59
I have a cub with dirt and corrosion in the fuel tank. Is someone reconditioning these tanks? How can I get in touch? Is there a recomended method to clean and stabalize the corrosion?
Bruce
wngrider@aol.com
C. Amick
09-22-1999 09:41:25
 Re: Farmall Cub Fuel Tank in reply to Bruce, 09-20-1999 20:38:59
I have heard of people removing gas tanks and rolling them around with gravel in them to remove the loose rust. There is a gas tank coating called Gas Tank Renu. You can call (313) 837-6122 to find the location of a dealer near you.
Chris
09-20-1999 21:42:57
I had to deal with my corroded tank for an entire year. First, I had it boiled out at a radiator shop. It got clean, but wouldn't stay that way. Then, somebody recommended that I use a fuel tank liner kit from JC Whitney. I just put on the last coat and plan to crank my Cub over in the next couple of days. It appears that it will work just fine. By the way, you may not know this (I found out a couple of days ago,) but the Cub has a baffle mounted across the tank. For a whole year, I couldn't even tell.
