McCormick 10-20
Brent in MO
07-01-2003 16:47:23
Where can I find the serial number on a 10-20? I just bought one that needs quite a bit, and I can't find the serial number. Thanks for any help I can get.
adam
07-08-2003 17:40:43
 Re: McCormick 10-20 in reply to Brent in MO, 07-01-2003 16:47:23
brent I just purchased a MD 1020 the serial number on my tractor is under the gas tank towards the rear of tractor .If anyone knows a good source for parts please post
thanks Adam
Bob Kerr
07-01-2003 21:35:15
Look just above the lower water return elbow on the left side of the block. There is a raised area in the block casting and it should have the serial number stamped into it. If the engine was never swapped out with another one, it will be the same as the serial number of the tractor. If you need any help getting yours going let me know. My 10-20 was a real mess when I got it and it runs just about perfect now.
oleblu
07-01-2003 18:31:57
Brent, look under the rear of the fuel tank. There should be a tag on the back side of the tank support, maybe to the right side, I think. oleblu
