Hydraulic oil leaking out of the dust cover on M
Black Creek Far
07-21-2003 23:25:15
My Farmall M is leaking hydrualic oil out of the dust cover by the belly pump. What might be causing that?
here, try this
07-22-2003 04:22:05
 Re: Hydraulic oil leaking out of the dust cover on in reply to Black Creek Farm, 07-21-2003 23:25:15
seal in the front of the pump
Farmer John
07-22-2003 07:14:51
 Re: Re: Hydraulic oil leaking out of the dust cove in reply to here, try this, 07-22-2003 04:22:05
Clean up the area around the hole with denatured alcohol. Fill the hole with JB Weld and let set for 24 hrs. Drive tractor normally for next 50 years, your leaking hole will leak no more,,,or you could drop the belly pump and replace the seals..
