Hydraulic pump seal.
Brian
07-25-2003 20:01:46
Howdy everyone, Can anyone tell me if the seal that goes on the output shaft of the hydraulic pump is still available ? It's a super A, not quite shur exactly what model of pump ( I understand that there were a couple ). If anyone has had any experience putting a "O" ring in I would be interested in knowing how it worked out.
Thanks All !
Brian.
CNKS
07-25-2003 20:08:19
 Re: Hydraulic pump seal. in reply to Brian, 07-25-2003 20:01:46
You can find the generic O-ring anywhere. If you have a groove on the shaft, it might still leak. You can have the shaft rebuilt by a good (emphasize good) machine shop, or do as I did, and have the hole the shaft goes through drilled out and use a speedy sleeve. Speedy sleeve is too large for the original hole. Some pumps have a regular oil seal, if yours does, a speedy sleeve will work fine.
Brian
07-26-2003 09:00:38
 Re: Re: Hydraulic pump seal. in reply to CNKS, 07-25-2003 20:08:19
Thank for the response !
