McCormick Deering 22-36
Brian
07-26-2003 19:04:59
I bought a 22-36 a few years ago and it has an aftermarket carb and manifold manufactured by a company called Robin. Does anyone have any information about this carb and manifold? I'd like to know if there are parts still available.
Ron Larson
05-20-2004 20:46:57
 Re: McCormick Deering 22-36 in reply to Brian, 07-26-2003 19:04:59
I have a 1929 Mck 10-20 with a Robin carb and mainfold. I need some parts for the carb as it leaks gas, but runs good. Did you find any source for Robin parts?
Thanks
Ron Larson
here, try this
07-27-2003 04:48:05
never heard or it. Is the carb made by Robin too?
Brian
07-27-2003 08:25:30
 Re: Re: McCormick Deering 22-36 in reply to here, try this, 07-27-2003 04:48:05
Yes the carb is made by Robin too. The whole setup is to convert from running on distillate fuel to gasoline. The carb has some parts that are quite worn, also this tractor has a throttle on it and I believe that originally they did not have a throttle the engine just had one governed speed.
here, try this
07-27-2003 17:44:56
 Re: Re: Re: McCormick Deering 22-36 in reply to Brian, 07-27-2003 08:25:30
you are right that the 15-30 or 22-36 did not have a variable speed govenor but they did have a throttle.
Brian
07-27-2003 18:34:12
 Re: Re: Re: Re: McCormick Deering 22-36 in reply to here, try this, 07-27-2003 17:44:56
I believe the throttle was actually a decelerator. I might have to replace the carb and manifold with factory parts if I can't find parts for the setup that is on it.
