Loose front end
abane
07-27-2003 04:11:42
I have a narrow front end on a FARMALL 400 and it seems extremwly loose.You don't notice it so much in the field at slower speeds but on the highway it gets so bad that sometimes you nearly have to stop. Is there a way to fix this and I know its caused by a worn worm gear.Any thoughts on this.
Dick Davis
07-27-2003 04:26:10
 Re: Loose front end in reply to abane, 07-27-2003 04:11:42
Very common problem with these vintage tractors and it has been discussed here many times. I recommend that you check the achives. There is a ton of info on how to correct the problem. If you can't find the info repost. Good luck.
