Super W6 clutch problems
Ben C
07-29-2003 05:55:49
Having problems with clutch slipping on Super W6, split tractor, replaced clutch and pressure plate with new unit fron Case IH dealer, and had flywheel resurfaced, put back together, hooked to pull sled, same problem slipped and only moved sled 2 feet, has been apart twice since, same problem, could the new parts be wrong? any help will be appreciated, thanks
JB
07-29-2003 18:45:21
 Re: Super W6 clutch problems in reply to Ben C, 07-29-2003 05:55:49
Is there any grease or oil residue on surfaces? Clean all clutch contact surfaces with with disk brake cleaner.
Several years ago a neighbor had the same thing with clutch for his winch on a log skidder. The problem was that when the machine shop turned the driving surface they did not do a large enough diameter and there was a small ridge left at the very outside. The winch would work until a heavy load was applied and then the clutch would slip because it was only making contact on the outer ridge.
Verify that your flywheel has been turned properly and the clutch disk makes contact with all the flywheel and pressure plate surfaces.
Jb
49 Cubber!
07-29-2003 18:00:28
How did you adjust the clutch fingers?I think clrearnace between the TO bearing and the fingers is about an inch or so.(Been while)
