1944 M Question
Brad
08-16-2003 12:26:42
On each side of my M are 2 ports. Are these for Hydraulic hoses? Left side are together and right one is below the belt pully, the other more up. I've seen a picture with a M with hoses attached.
What are they for and what are they good for?? What implement do the hoses hook to?? Any help Thanks
Nebraska Cowman
08-16-2003 17:24:53
 Re: 1944 M Question in reply to Brad, 08-16-2003 12:26:42
yup. all 3 are pressure. if you want a two hose setup u will have to plumb a return back in to the fill pipe.
charlie
08-16-2003 13:36:31
Those ports are for hydraulics. Implements such as cultivators have hoses that attach to them. One fo the ports on the left side may have a delayed lift as the idea was to wait on lifting the rear section until the tractor wheels were at the end of the row. You can connect a length of hose to one of the ports and run it to the rear of the tractor to lift trailer implements such as plows.
