Push / Pull On/off Switch for Super A
brian
08-18-2003 18:46:54
Can anyone tell me if there should be a difference in the hole size for the 1 and 2 prong switches ? I bought a 2 prong and it doesn't fit.
thanks
Brian
08-19-2003 18:58:18
 Re: Push / Pull On/off Switch for Super A in reply to brian, 08-18-2003 18:46:54
I do have the thick washer, the stop washer and the cap. When I tried to poke it through the hole between the light switch and the amp gauge, it just wouldn't fit through. I looked for the notch to make sure it wasn't hanging up on it too. I'm wondering if there is a difference with just the switches for the Super A's. I know I could just drill it out to make the hole bigger ... but I hate doing that.
Hummmm
Thanks Brian.
BIG JOHN
08-19-2003 15:02:58
Brian - As you know the switch does not go into any dash or switch box, it has it's own bracket on the steering column. Both the single pole and double pole switches are the same size.
justin
08-18-2003 20:45:57
Now does it not fit due to the diameter of the hole, or does it not tighten down on the insturment panel" The single and double pole switches are the same diameter, I just assume that you don't have the extra thick washer that takes up the slack so the switch fits tight to the insturment box..
Nebraska Cowman
08-18-2003 18:48:53
i thought they were the same
