Repolarizing a Generator?
Ben
08-18-2003 19:09:12
I need to repolarize my generator for it sat about two years with no battery. The problem is I was told to get a short wire and connect a jumper between the "BAT" terminal and the "A" terminal of the generator. Does the "BAT" refer to the positive on the battery? Which termial is the "A"?
steve
08-18-2003 19:22:19
 Re: Repolarizing a Generator? in reply to Ben, 08-18-2003 19:09:12
the terminals on the generator are "A" and "F", should be marked. THe terminals on the regulator are marked "B", "G(A)", and "F". THe B goes to the battery, the G and F go to the generator terminals A and F. All you need to do is touch the B and G terminals of the voltage regulator together for 1 second. Then startup.
