1256 PTO quit working
Brian in MO
08-23-2003 20:08:52
Ok guys we were bailing hay today with the 1256 one guy stopped and shut the tractor off a few hours later I get on it and the PTO will not come on. Any ideas? The hydralic fluid is OK and everything else works like normal. Guess I know what I'm doing tomarrow. Thanks Brian.
Aces
08-24-2003 19:41:01
 Re: 1256 PTO quit working in reply to Brian in MO, 08-23-2003 20:08:52
I would not think the clutches would go that fast, it sounds more like the pin in the valve.
j meyer
08-24-2003 10:49:21
Brian- I'm a mechanic at a Case IH dealer and what your tractor needs is a PTO rebuild. Your PTO disks are fried and I have done about 5 of these repairs since the 4th of July here. Its an easy repair to do with the PTO repair kit we have, but if your not sure on doing it, flat rate is about 8 hours, if you want your local dealer to do it for you...
riverrat
08-24-2003 07:43:26
Had a pto quit working just like that all of a sudden on a 1486 one day. Shut it off, then wouldn't come back on. Had to pull whole pump out the back and get it rebuilt. The clutch pack, you know? That sucker's heavy. Not to burst your bubble, but this is a possibility!
w gatewood
08-23-2003 20:15:47
yes if the linkage has lots of slop in it you broke a roll pin in the bottom of your linkage been there done that.
Brian in MO
08-23-2003 20:24:32
 Re: Re: 1256 PTO quit working in reply to w gatewood, 08-23-2003 20:15:47
The linkage doesn't have alot of slop but I was wondering if the is a roll pin inside the housing could have broke. Thanks
wgatewood
08-23-2003 20:34:51
 Re: Re: Re: 1256 PTO quit working in reply to Brian in MO, 08-23-2003 20:24:32
brian call me my # is 317-748-1468 ill tell you by phone where to look thanks wilson gatewood i am still up its ok to call
