Farmall B - Fuel Filter
Big Tex
08-25-2003 14:53:45
How Often should I Remove the fuel filter & clean it? What steps do I take to accomplish this?
Andy Martin
08-25-2003 16:13:50
 Re: Farmall B - Fuel Filter in reply to Big Tex, 08-25-2003 14:53:45
Assuming you mean the sediment bowl, only when you see a buildup of sediment in the bottom of the bowl.
If you see a line across the bowl, this may be the interface between water in the bottom and gas at the top. This also indicates a need to clean. My experienced hay hand finished raking a field with the choke mostly pulled out to get the tractor to run. He had removed the carburetor bowl twice to try to clean it out. The sediment bowl was completely full of water. Tractor ran fine after I dumped it. He was a little embarrassed.
To clean the sediment bowl, use a little carburetor cleaner to clean the threads, if necessary. Shut off the fuel (L shaped lever at top of housing), unscrew nut under bowl, remove and clean. If it has not been off in a while be ready to replace the gasket. If it is a glass bowl try not to drop it (very easy to do). Reinstall and turn the gas on. If the carburetor is full of gas the bowl may not fill up. Don't worry, it will after you start it. Rinse the spilled gas off with water before you start the tractor. In the field you can use a cup full from your water jug. It rinses off pretty easily. Just a little will not cause a problem, but gas spilled on the starter-mounted switch can be a big problem if not rinsed off. If you can let it set for a couple of hours all the flammable components will be gone even though the smell is still there.
I burned one C by not rinsing it off. Almost had the fire out when the fuel bowl broke and caught the rear tires.
Red Dave
08-25-2003 16:08:57
Depends on how much dirt is in the gas tank. I clean mine out at least every time I change the oil, more often if it looks dirty.
If it has the original style sediment bowl, turn off the tank valve, then loosen the thumb nut under the bowl, take it down, then using a small screwdriver carefully pull down the screen above the bowl, clean it, then put it all back together.
