Order Farmall Cub Parts Online
CUB clutch
Bob
08-26-2003 17:22:12
I have a CUB that I am having clutch problems with. I bought a new cluth/pressure plate and throw-out bearing, and put it together and the first time I stepped on the clutch it busted all the fingers off of the pressure plate. I looked in the inspection hole and it looks like the fork is going to far forward. What should I adjust to cure this problem? The person I bought it from would just start the tractor in gear, so I guess I should have investigated alittle more!
ME rock farma
08-26-2003 18:19:57
 Re: CUB clutch in reply to Bob, 08-26-2003 17:22:12
The fork is not suppose to move that much. make sure it is in the right set of holes ( I cant imagine there are any others that it would fit into) I just did mine this spring and it seemed to be pretty straight forward. Maybe the throwout bearing fork can be put in backwards??
