230 Farmall oil levels and types
Bryan
08-26-2003 20:38:56
What is the oil type used in the trans. gearbox and what is the correct level? It doesn't smell like 90wt. but I'm fairly sure thats what it shoud be. Thanks for any information.
Jay
08-27-2003 06:29:41
 Re: 230 Farmall oil levels and types in reply to Bryan, 08-26-2003 20:38:56
The new spec for this is HTF or Hy-Tran. Having said this, I would check w/ your Case/IH dealer. It probably called for 80-90, or 90 when it was new. In terms of viscosity, most hydraulic oils would be about a 75w85 if measured as they do gear lube.
So basically, if you want to use Hy-Tran, you are safe, if you would like something stiffer, check w/ your dealer.
I *think* the check plugs are normally on the side, about 1/3 of the way up.
