polarizing generator? what does it do?
Bob Quale
09-05-2003 18:58:03
What does polarizing the generator do? and does the charge of the battery have anything to do with it?
Bob
Red Dave
09-06-2003 06:30:22
 Re: polarizing generator? what does it do? in reply to Bob Quale, 09-05-2003 18:58:03
It establishes a magnetic field in the field coils of the generator, which the armature rotates through to produce electricity used to recharge the battery. It requires a charged battery to initiate it.
In my business, (electric generation) we call it flashing the field, same thing, same effect.
Doug in OR
09-05-2003 20:58:21
Polarizing the generator determines if the "ARM" terminal will be producing a positive (negative ground system) or a negative (positive ground system) output.
It doesn't have any effect on how much the generator will charge. The charging rate is determined by the engine speed and the "FLD" terminal potential, among other things.
