Farmall 400 Engine Rebuild
Bill
09-09-2003 09:24:20
The engine in my 400 is due for an overhaul. My brother suggested that I have the sleeves bored out to 4-1/8 inches (the bore of a 450) and put 450 pistons in it. Is this possible? Which head gasket would I need?
Jim
09-10-2003 09:33:21
 Re: Farmall 400 Engine Rebuild in reply to Bill, 09-09-2003 09:24:20
I have a set of IH Firecrater pistons and sleeves used but in very good condition with new rings and wrist pins that will fit and give you 281 displacement. You will need M or Super M rods since these are from a Super M. All will fit. If you are interested please contact me. Price about half of new. I also have available rods.
John In Iowa
09-09-2003 20:57:01
The 400 came with 4” pistons and IH came out with 4 1/8 pistons upgrade when the 450 came up. With the upgrade it still isn’t a true 450 because IH changed the cam in the 450. You have to check as to what wrist pins that you have. The early 400 had 1 1/18” wrist pins in the pistons and the late 400s had the 1” wrist pins.
John In Iowa
Bill
09-09-2003 19:02:43
Update on 400 engine rebuild: We took the head off on Sept the 9. Randy Hall is correct. This thing does have 4-1/8 sleeves, but the pistons are absurdly loose and wobble a great deal. The sleeves are badly scratched also. We're thinking that someone installed 450 sleeves but kept the old pistons. When I get some part numbers on these things, I'll post an update and seek advice. Almost forgot: Lots antifreeze on top of the head. Oh what fun.
randy hall
09-09-2003 18:43:15
i would be surprised if it doesn't already have 4 1/8" pistons in it from a previous overhaul.
Joe's460 Got No T/A
09-09-2003 10:45:27
The ghost of that 400 will haunt you.
JoeW-9
09-09-2003 10:40:09
Just paint your 400 to match a 450's color scheme, and change the emblems. Whose gonna know?
CNKS
09-09-2003 18:47:54
 Re: Re: Farmall 400 Engine Rebuild in reply to JoeW-9, 09-09-2003 10:40:09
By the way 209.41.233.211, why do you change your name each time you post?
Joe Evans
09-10-2003 05:30:15
 Re: Re: Re: Farmall 400 Engine Rebuild in reply to CNKS, 09-09-2003 18:47:54
Shouldn't have done that. I recognized the post as coming from my brother, and I wanted to tweak him a bit. This isn't the place for that stuff.
CNKS
09-09-2003 18:43:05
Someone who buys the tractor thinking it is a 450, and who does not check the serial number or prefix. There are already too many "upgrades" caused by a spray gun or decals already.
supermpuller4
09-09-2003 10:14:52
Just get the thin sleeve kit and make it a 450.
